Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ProblemConnecting more than one Orbi outdoor to
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-16
09:20 AM
2019-01-16
09:20 AM
I have a RBK50 inside and need to get WiFi in another building.
With one outdoor Orbi it just gets there but with an intermittent strength.
So I put another outdoor half way
This one struggles to connect.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-16
09:41 AM
2019-01-16
09:41 AM
Re: ProblemConnecting more than one Orbi outdoor to
Whats the distance to the remote building?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-16
09:42 AM
2019-01-16
09:42 AM
Daisy Chain has to be enabled for this to work? Is it enabled for you?
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-16
09:50 AM
2019-01-16
09:50 AM
Thank you
Could you let me know how to set daisy chain on the Orbi outdoor
Regards
Mark
Regards
Mark
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-16
09:51 AM
2019-01-16
09:51 AM
Set Daisy Chain ON the Orbi router under Advanced Tab/Advanced Settings/Wireless Settings.
@Markliley wrote:
Thank you
Regards
Mark
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-16
09:56 AM
2019-01-16
09:56 AM
Daisy Chain can be found under >>ADVANCED>>Advanced Settings >> Wireless Settings.
Please note that you need to have the nearest Outdoor Orbi synchronized with the router first so that it will start broadcasting its backhaul network that the second Outdoor Orbi will need then to synchronize to.
Message 6 of 6
Announcements
