Orbi WiFi 7 RBE973
Reply
Purple Ring when in router mode
Kopper
Follower
I have TDS fiber and am unable to use my Orbi in Router mode.  When plugged directly into my ONT (no router or double NAT involved), I get a 6 hour DHCP lease from my ISP.  The Orbi seems to lose connection about half way through.  It provides excellent coverage in AP mode, but is really unreliable in router mode.
Firmware is 2.7.2.104 (made great improvements for easy setup to handle TV streaming with IGMP).  I *love* the Wifi range and use this the Orbi exclusively for it in AP mode...letting my ISP router handle everything but WiFi.
I'd like to use Orbi in router mode to take advantage of advanced features and not have to rent a router from my ISP.  All advice is appreciated.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Re: Purple Ring when in router mode
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Message 2 of 3
CrimpOn
Guru
DHCP protocol specifies that the device should begin asking to renew the lease when half of the lease time has expired.
https://en.wikipedia.org/wiki/Dynamic_Host_Configuration_Protocol
This sounds suspiciously like the ISP is receiving the renewal request and denying it.  The ISP Technical Support will almost certainly deny it.  I still recommend calling them and pleading the case.  Maybe they'll give you a 7 day lease so this happens only once a week?  Orbi's are pretty common, so maybe they have notes on how to support customers with Orbi.
It will be a chore to collect data to support (or reject) this possibility.  What I would do is use the Orbi feature to "Enable LAN/WAN Packet Capture" on the debug page (http://orbilogin.net/debug.htm).  Start the capture when there is about 3 1/2 hours remaining on the lease and capture until the Orbi loses connection.  Then save the file to a PC and use Wireshark (free) to look at the wan.pcap file. There is a display filter at the top of the page. Enter "dhcp" (lower case) and click the arrow.  This will show all of the DHCP packets that have been captured.
Wireshark records the packet time in seconds from the beginning of the capture, so if you started capturing about 30 minutes before the lease is half over, somewhere around 1800 seconds there should be a DHCP renewal packet from the Orbi public IP address and then a response from the ISP.  I don't know about fiber systems, but my cable sytem records the DHCP broadcasts from every computer on the subnet, so there is a lot of data to look through.
This is a lot of hassle and a significant investment of time.  Personally, I LOVE this sort of thing, and would do it even if the results turn out inconclusive.  You may realize that "this is not worth it."
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 686 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
