- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
QOS on RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
QOS on RBR50
I am perplexed about the QOS setting having nothing more than a Speed Test button? Is it me? How are we suppose to assign priority?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
MightyT:
No, it is not just you. My setup also has only the SpeedTest option for the QoS Setup. I don't know if any other options for this are coming or not. You'll have to wait for a response from someone from Netgear.
Sorry about that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
You cannot set priorities.
Orbi has the GUI for NETGEAR's "Dynamic QoS." This uses speed test results to manage bandwidth. This type of QoS, where the only settings required are upload and download speed is common, and is used by Eero, Mikrotik, Edgerouter, and other NETGEAR routers. You can click on the "?" help icon on the QoS page to read about how it's supposed to work.
However, I tested Orbi's QoS using the dslreports speed test, and it doesn't seem to have any effect on buffer bloat, so it doesn't seem to work at the moment. Maybe it will be enabled in a future fimrware release. Who knows.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
@Jeremyinsf wrote:
http://orbilogin.net/QOS_main.htm
Have you tested your router to see if the settings on this hidden page actually work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
I'm not currently using it as I have 1Gb symetric fiber and that's far more than I need to use, let alone prioritize.
However, when I was on DSL previously and needed to share limited speeds with voip and vpn, it seemed to help.
Do you have indication that it does... nothing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
No. In my testing, the non-hidden QoS page seems to do nothing, so it would be odd for this hidden QoS page to work.
I have not tested this hidden page myself, and I have never seen a post from anyone who has tested it. However, there are many posts on here wanting QoS, so it would be good to know if this actually works.
I use a third party router, so I don’t currently need QoS on Orbi either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
The QOS is basically broken and does nothing. It's one of about 10 things I wish netgear would fix. They either employ really dumb engineers or just plain don't care.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QOS on RBR50
