- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Quel Satellite additionnel pour RBK40 ...
Bonjour,
Je possède un kit RBK40-100PES, qui est composé du routeur RBR40 et d'un sattelite RBS40.
Je souhaite etendre mon réseau, suis-je "Obligé" de mettre un autre sattelite RBS40-100PES,
Ou puis-je mettre un sattelite additionnel RBS20-100PS ? Est-il 100% compatible avec le routeur RBR40 ?
Je ne trouve cette info nulle part,
Merci d'avance de votre aide à tous
Cristofe
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Quel Satellite additionnel pour RBK40 ...
Oui.
veuillez utiliser l'anglais. Je vous remercie.
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
I own a kit RBK40-100PES, which is composed of the router RBR40 and a sattelite RBS40.
I want to extend my network, am I "obliged" to put another sattelite RBS40-100PES,
Where can I put an additional sattelite RBS20-100PS? Is it 100% compatible with the RBR40 router?
I can not find this info anywhere
Thank you in advance for your help to all
Cristofe
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I believe you can use a RBS20 with the RBR40.
30 feet is recommended in between base router and satellite to begin with depending upon building materials.
I recommend contacting NG support in your region to confirm that the RBS will work for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
RBS20, RBS40 and RBW30 should be compatible with RBR40, as all these devices are AC2200 (2x2 backhaul).
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thx a lot for your help...!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Good Luck.
