- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Question on RBR50 WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just hooked my RBR53 system up with the 2 Satellites. Is there a reason why the 2.4 is stronger the the 5g? It is on all my devices. I would have thought the 5 would be higher, Thanks for your reply Jerry
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved!. When I had my old routher 2.4 and 5g both came up as networks. Now with Netgear only 1 name comes up and it routes the device to the stronger connection. I did not know this. Must have been hooked up to an old 5g that wasn't working well this morning.. Thanks for all the help, Jerry
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Question on RBR50 WiFi
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
You can reduce the power output of the 2.4Ghz radio if needed. Under Advanced Tab/Advanced Settings/Wireless Settings
Do any of your devices connect to the 5Ghz radio SSID?
Are you using a custom SSID name or the default one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Josser wrote:I just hooked my RBR53 system up with the 2 Satellites. Is there a reason why the 2.4 is stronger the the 5g? It is on all my devices. I would have thought the 5 would be higher, Thanks for your reply Jerry
5G WiFi signals attenuate more with distance than 2.4G and do not penetrate materials as well as 2.4G. The maximum WiFi power level is set by each country. In the US, it appears that both 2.4G and 5G WiFi have a maximum power level of 1 watt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
E
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
Noticed 5g network is not showing now?
Modem Model # is Calix model 716ge-1
Distance is a little more than 30 ft on satellites but hooked up well
All connect to the 5g just not as strong a signal but 5g is not showing now and I am right next to the router? Have not tried your other methods yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this, reduce the power on the 2.4ghz radio to 25% then walk around and see what your devices do.
Possible you may have a bad unit out of the box possibly.
What is your home materials made up of?
- Mark as New
- Bookmark
- Subscribe
- Permalink
House is just board walls on the inside, concrete and wood on the outside. How do you decrease the 2.4ghz radio
@FURRYe38 wrote:Try this, reduce the power on the 2.4ghz radio to 25% then walk around and see what your devices do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I am just going to contact Netgear support on this one to see what they say.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes with NG support.
Inside should be ok for signal travel. Concrete outside walls should be impact accept you won't get much signal outside of these walls.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, Orbi uses a signal SSID name for both 2.4Ghz and 5Ghz radios. It will help dual band devices get connected to either frequency, however it's up to the connecting device to pick which frequency.
Enjoy.
