Reply
Questions before buying Orbi
mfmguy
Follower
Hi there, Have a small resort which was purchased by 6 families. There are 6 cabins on the property with 1 garage. Property is about 350' x 250'. Max distance between cabins is about 100'. Cabin size is small, about 800sf - 1,100sf per cabin. I am more worried about coverage(range) than speed. I want to make sure each cabin has good signal. Anyone have a recommendation on how big of an ORBI system I would require, at least to start with? Thanks, Mike
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 3
tsig
Luminary
Re: Questions before buying Orbi
sounds like you need a commercial system, not a residential system.
RBR50, 2 RBS50's AP Mode, wireless backhaul
Message 2 of 3
Guru
You can review NGs Pro/Outdoor series.
https://www.netgear.com/orbi-pro/rbs50y.aspx
I would contact NG to see if this would meet your specifics. Again you may need more of a Commercial grade system.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 605 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
