Orbi WiFi 7 RBE973
Reply
R6700 Firmware Version Update File downloads corrupt?
HenryHawk
Follower
Setting up a NETGEAR AC1750 Smart WiFi Router (R6700) and was a little surprised to find that firmware update (V1.0.2.16_10.0.57) downloaded from Netgear Support as "recovered file fragments".  Also downloaded updates for ReadyShare Vault and ReadyShare Printer, not surprisingly they appeared to download as expected - as common file types.  Does anyone have any SOLID info as to why this occurred when downloaded directly from the manufacturer's website?  I don't know which type of OS Netgear caters to most often, but last I heard Windows was still the leader as most common Operating Systems installed on PC's worldwide. At this point in time NETGEAR doesn't get a 'pass' simply because the firmware was downloaded from their website.  Please.  I think they owe it to their customers to get it together, that is if they want those customers to ever purchase again in the future.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
Guru
Re: R6700 Firmware Version Update File downloads corrupt?
I just downloaded and extracted it without issues on a windows pc.
Did you extract the zip file?
And then are you uploading it to the router or trying to open it?
Its not a file you open but that you upload.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
Message 2 of 4
Guru
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Message 3 of 4
antinode
Guru
> [...] firmware update (V1.0.2.16_10.0.57) downloaded from Netgear
> Support as "recovered file fragments". [...]
   How Windows File Explorer describes a file (based on its name
extension, like, say, ".chk") and what that file actually is may be
entirely unrelated.
      https://community.netgear.com/t5/x/x/m-p/1721037#M124018
      https://kb.netgear.com/23960
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 692 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
