Reply
RB53 vs RB50 for 5000. Sq ft
Sogavol
Follower
First of all I am not very tech savvy so thanks for any input.
i went ahead and got the 53 with 2 satellites figuring overkill would be better since I was wanting some coverage behind our house.
i just read something that each satellite use a dedicated band for backhaul to the router and that the extra satellite may actually clog up the system and hurt speed.
thanks for the help.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 4
st_shaw
Master
Re: RB53 vs RB50 for 5000. Sq ft
You should be fine.  I have one router and two sats in a 3,000 SF 3-level home with no issues.
Message 2 of 4
Guru
I use a base router and just satellite for my 5000sq ft home.
Recommend 30 feet to begin with in between the base router and satellite(s).
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 3 of 4
DavidShawP
Star
I have the RBK50 with two RBS50 satelites for a 6000 sq ft home and it works great -- in fact I can get wifi out in my driveway all the way to the street.    You should be fine.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 933 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
