Orbi WiFi 7 RBE973
Reply
RBK 13 Satellite LED Flashing Red
Pedro_Gemelgo
Hi, hope someone can assist, I have a satelitte AP that is flashing Red meaning the Firmware is corrupt, can anyone assist me on how to get this back to flashing white so I can Sync with main router?
I have tried the reset button for up to a minute and nothing happens, the LED remains flashing red.
Thank you in advance....
Message 1 of 4
Guru
Re: RBK 13 Satellite LED Flashing Red
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 4
Pedro_Gemelgo
Hi, thank you for the response and the process.
The process if for fixing the Main Base unit and not the Satellite that is the problem, I dont have a problem with the Main Unit. It came with 2 sattelites, one is working and the other is flashing red, that is where the problem is. How to fix the Satelite.
Any input for me on this?
Thanks in Advance.
Message 3 of 4
Guru
My bad, the satellites on that system don't have an ethernet port for tftp/nmrpflash.
If a factory reset does fix it, then you'd need to open a support case with netgear.
Click on "mynetgear" at the top. register an account and the device. From there you can contact support ( to check on warranty)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 573 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
