Orbi WiFi 7 RBE973
Reply
RBK 13 connect to Printer
routerks
Tutor
Hi,
I have new RBK13 Orbi Wifi system and would like to know the process of connecting this to my Canon printer which needs WPS.
Thanks in advance for any suggestions or workaround to connect.
Kiran
Message 1 of 5
Guru
Re: RBK 13 connect to Printer
Have the printer connect to the SSID name and PW set on the RBR for wifi?
Please contact the mfr for help and support information regarding there product.
Message 2 of 5
CrimpOn
Guru
The RBR10 User Manual explains on page 16 how to use WPS to connect devices, such as printers:
https://www.downloads.netgear.com/files/GDC/RBK12/RBK12_13_14_UM_EN.pdf
Message 3 of 5
routerks
Tutor
Thank you very much for the response. I will try this option.
Message 4 of 5
Trudeau159
  1. Remove ALL security from my WiFi network.
  2. Use WPS to connect the two.
  3. Check ORBI webpage and ensure that printer shows up as a device.
  4. Go directly to the IP address of printer noted in 3.
  5. Logon directly to printer interface d - password was in the manual.
  6. Manually enter the SSID and password.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 514 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
