Reply
RBK 13 password
Thisted
Follower
RBK 13 password
Where do I locate password on the RBK10 router. I purchased the RBK13 system with two satellites. Instructions indicate that it is located on a label but the only label on the unit shows SN and MAC. Thank you in advance...
Message 1 of 3
Guru
Re: RBK 13 password
You can log into the device to access the ssid/password as well as change them.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 3
Mstrbig
Master
Re: RBK 13 password
The default user name is admin. The default password is password. The user name and password are case-sensitive.
To recover forgotten password:
  1. Launch your browser and go to my.netgear.com/registration/login.aspx
  2. Select the "Forgot your password?" option to access the "Reset your password" window.
  3. Submit the email address used when creating Orbi account.
  4. Fill other fields and click "RESET MY PASSWORD".
  5. Go to your email and open the link sent by NETGEAR Support.
  6. You should be redirected to the NETGEAR Change Your Password page.
  7. Enter a new password and click "Submit".
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 396 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
