- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK-43S blocks HULU, Pandora, other streaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just bought a RBK-43S orbi router with 2 satellites from BestBuy. Set up and all tells me working ok. I can connect devices to oribi network but once i go to stream an app like HULU, Pandora, etc -- nothing. either error on Hulu or inifite thinking on other apps. Any advice? thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
NOTE TO ALL
Thank you for the assistance.
- Changed ATT Modem - turned WiFi OFF
- Connected directly to ORBI via cable
- signed onto orbi login site;
- changed settings to AP
- ALL APPS working as expected.
thanks again
MDAK1ATL
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK-43S blocks HULU, Pandora, other streaming
Tell us about your modem?
Orbi firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
orbi firmware: V2.3.5.30
Modem is from ATT - Uverse
I do not see a mfr. but model number is 5268AC / FXN
Not sure if it matters, but when i open the Orbi App, dashboard shows the 2 satellites connected and any devices have i have connected. However, at the top, next to INTERNET it says "OFFLINE" but i can use the web for general purposes thru orbi
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@mdak1atl wrote:orbi firmware: V2.3.5.30
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may be dealing with a 2 router situation (Orbi + the AT&T)...??
What was your setup before the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before ORBI ---
@Retired_Member wrote:You may be dealing with a 2 router situation (Orbi + the AT&T)...??
Used ATT modem/router to connect all household devices - wired and wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mdak1atl wrote:Before ORBI ---
This sounds like you did NOT have a second router. Now with the Orbi you bring another router in the picture which requires a differrent configeration. You made need to set the Orbi router in the AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, seems abit complex for a novice network person like me. I will investingate the info and links. Thank you again. I have some questions down below in your text...
@FURRYe38 wrote:Modem Combo Units:
This would be a double NAT (what is NAT?) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode. It ORBI not in router mode now?
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Network Address Translation (NAT) is the ability of a router to translate a public IP address to a private IP address and vice versa. It adds security to the network by keeping the private IP addresses hidden from the outside world.
When you hear people in here talk about NAT it's usually in a case of 2 routers in the same network.
if you did nothing to it, it probably is which is your problem since the AT&T device is probably also in the router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mdak1atl wrote:Thanks, seems abit complex for a novice network person like me. I will investingate the info and links. Thank you again. I have some questions down below in your text...
This would be a double NAT (what is NAT? http://computer.howstuffworks.com/nat.htm
http://www.practicallynetworked.com/networking/fixing_double_nat.htm) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode. It ORBI not in router mode now?Yes the Orbi is in router mode. Need to get the modem either bridged fully with the help if your ISP or try option #2 below.
Hope that helps.
You'll have to keep the ISP Modem as ATT Uverse services require the use of the ISP modem and not a customer bought modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One other item, I would ask AT&T if you must use their modem. If not, I would dump the AT&T modem and buy your own modem only device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Understood --- wish i could dump ATT all together!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think the Uverse modem can be briged if I remember correctly. I would give Option #2 a try first, then try Option #3. Either one of these should get your streaming services working for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I will try the solution suggestions here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
Hope that helps.
Hello @FURRYe38
I tried Option 3 -- ran into a snag almost immediately. I walked thru the video, connected to ORBI WiFi network. It showed CONNECTED.
Then went to www.orbilogin.com --- this is what I get: " Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us." What should I do different or try? thank you.
MDAK1ATL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using a wireless or wire connected PC or laptop when your configureing AP mode? If wireless it means that while walking thru this process, you have to get your PC or laptop connected to the Orbi SSID name. Be sure you set up a custome SSID name for the wireless. Can be anything.
Why wire connected PC or laptop is best for this setup configuration connected to the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My PC connected to the ORBI (with a customized name) via WiFi. Orbi router wired directly to ATT modem. I will try connecting via direct wire to Orbi. thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ensure the WiFi on the modem is turned OFF as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still working on this solution -- wanted to keep the string alive for now. thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Let us know how it turns out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NOTE TO ALL
thanks again
MDAK1ATL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
