Orbi WiFi 7 RBE973
Reply
RBK-53: Strange problem after firmware upgrade
sh2sg
Apprentice
It is reproduceable, encountered the same problem since every 2.3.x firmware.
Login to Orbi admin,
On the firmware upgrade page, new version of firmware is available for RBR-50 and 2 RBS-50.
Select upgrade all, and wait untill all nodes are done.
Everything looks fine, devices are able to connect back with no issue.
~10 hous later
Devices are dropped from all satellites, it shows connected but no Internet.
Orbi app network maps shows GREEN on all satellites, but no connected devices
Router RBR-50 is fine.
Restart all RBS-50 (power off and then on) solves the problem.
No more connection problem until next upgrade...
This happens after every v2.3.x upgrade (2.3.1.60 / 2.3.1.48 / 2.3.1.44)... very annoying...
Any idea?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: RBK-53: Strange problem after firmware upgrade
Is the Orbi system operating in Router or AP mode?
Has a factory reset and setup from scratch with out loading any saved backup config files been performed after v60 was loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 4
sh2sg
Apprentice
this only happened 10 hours after firmware upgrade, and didn't come back again after the reboot. i dont think it has anything to do with house size, neighbors' wifi, distance etc.
devices had full signal to satellites but couldn't connect to them, it looked like IP conflict to me, after upgrade, satellites IP lease somehow became out of sync, expired 10 hours eariler soemthing and RBR-50 wasn't aware of it until reboot satellites.
RBR-50 is using in AP mode btw.
Message 3 of 4
Guru
Please give feedback to the questions presented so we can get an idea of your situation.
Also try a full factory reset on the system and setup from scratch.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1127 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
