- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK 53 internet issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
I have been using orbi RBK53 over 8 moths and I am satisfied with my experience.
Recintly I am facing in issue with the internet, it keeps disconnecting and shows that there is no internet connected to the device. But, I am sure that the internet is working properly and I have tested it several times.
How do I solve this issue?
My guess that the formware has some issues and caused this problem!
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK 53 internet issue
What modem are you connected to?
What firmware is on it?
Does it happen to all devices? Wired devices? only wireless devices? only devices connected to a certain satellite?
How frequently is it happening?
What speeds do you pay for?
What speeds do you get hardwired into the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Huawei HG8245Q
the latest one
yes the orbit disconnects from the internet suddenly and shows the pink light the same light that appears when the internet is off, but it is not.
evry few minutes
100 mega
100 mega
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mohammed997 wrote:What firmware is on it?
the latest one
Alas "latest one" is ambiguous. The Orbi Firmware Update web page may say, "No firmware update available", when there actually is "newer" firmware on the support web site. That's why the specific firmware release number is useful to know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your modem/ONT already has a built in router and wifi:
https://support.huawei.com/enterprise/en/doc/EDOC1000099317
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@mohammed997 wrote:What modem are you connected to?
Huawei HG8245Q
the latest one
evry few minutes
100 mega
100 mega
- Mark as New
- Bookmark
- Subscribe
- Permalink
i checked the firmware version it was 2.5.1.8, so I have updated to to the last version 2.5.1.16 by doing it manually. I will test if the problem goes away or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may need a factory reset and setup from scratch if you notice more problems. Also be aware if your ISP Modem/ONT router configuration as well.
