- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK 852 - WAN aggregation
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm looking to leverage the WAN aggregation feature on my RBK 852 (2.5 Gbps + 1 Gbps, LACP-IEEE802.3ad), potentially through two 1000Mbps FTTH connections.
I'd like to know:
(1) If both connections are from the same ISP but via different modems, whether I need any configuration from my ISP end - e.g. bonding. What will happen if I simply plug in the two cables after setting things up on the Orbi webpage?
(2) If both connections from the same ISP and via the same modem (i.e. 2 ethernet cables come out from the same modem), do I need specific settings on the modem? What will happen if I simply plug in the two cables after setting things up on the Orbi webpage?
(3) If the two connections are from 2 different ISPs, would that work? Is it possible to make it work?
Any thoughts and advice would be most welcome! Thanks!
ML
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Review the user manual.
Good Luck.
@masterlau wrote:I'm looking to leverage the WAN aggregation feature on my RBK 852 (2.5 Gbps + 1 Gbps, LACP-IEEE802.3ad), potentially through two 1000Mbps FTTH connections.
I'd like to know:
ML
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
I'd like to know:
ML
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK 852 - WAN aggregation
You should be able to use links from two different ISP's provided the ISP modems support Link Aggregation Control Protocol (LACP).
More information here: https://kb.netgear.com/000061324/How-do-I-set-up-WAN-aggregation-on-my-Orbi-WiFi-6-System
