- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK20 - Orbi Log-in Fail and no option to reinstall
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi people,
Far passed the point of frustration. Since a couple of days, my RBK20 router has stopped working.
I've been trying to reinstall several times, but the iPhone app doesn't recognize my credentials (incorrect PW - which is obviously not the case).
The router and (1) satellite are connected, it's just that it doesn't allow me to complete the network setup.
A complete new installation hasn't worked so far, since every time it needs the app to get a safe home network. What I've been trying:
i) Full new setup and resets, many times
ii) Trying to access the router through its IP-address; Resulted in a complete setup, but not accessible since it was unsafe and couldn't be used
iii) Updated all firmware
Really not sure what else I can do. Any help is much appreciated.
Gideon
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK20 - Orbi Log-in Fail and no option to reinstall
What do you mean by "since it was unsafe and couldn't be used"? If you refer to the "unsecure" warning that you get from your browser, then you can just accept an exception and continue or use http not https to access the IP address of Orbi, you can also just use orbilogin.com and you will be automatically directed to the Orbi IP address of the router.
For the Orbi phone app, if it has been configured previously with another password, then I think that you need to uninstall the app and install it again to be prompted for the password again.
Good luck 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
Try a factory reset on the Orbi router and wire connect a PC to the back of the router and use a web browser and navigate to orbilogin.com and walk thru the setup wizard here.
@gmsteeds wrote:
Hi people,
A complete new installation hasn't worked so far, since every time it needs the app to get a safe home network. What I've been trying:i) Full new setup and resets, many times
Gideon
