Reply
phis5533
Tutor
RBK20 and HomeKit issues
Hello everbody,
I just bought a set RBK20 (RBR20 + RBS20), respectively at the levels of FW
V2.6.1.36 and V2.6.1.38.
My RBR20 is connected by WAN directly to the Orange France ISP fiber ONT and configured to connect without the TV.
Everything is working properly except my Homekit devices, whether they are electrical outlets, my roller shutters, cameras, Hue, etc.
Indeed, 2 times out of 3 when I question my Home application, some are noted "not responding", and this in a random way, both locally and outside my network.
My devices are in iOS14, my Apple hub are HomePod and AppleTV4K.
While trying to find out about this site, I read some problems, normally solved since FW 2.1.4.16, which is not my case.
I have tried modifications like the ones described in this post:
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-HomeKit-Issues/m-p/1654959/thread-id/44026
Today my configuration the most stable is :
20/40Mhz cohabitation : uncheck
CTS/RTS threshold : 2307 both 5GHz & 2,4GHz.
Long preamble
Daisy Chain : uncheck
Beamforming : check
Mu-Mimo : check
Fast Roaming :check
Should I downgrade my FWs to 2.1.4.16?
Please help me solve this huge problem.
Philippe
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: RBK20 and HomeKit issues
Try a factory reset and setup from scratch. If this fails, downgrade back to v16 if that worked for you.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 4
phis5533
Tutor
Hello @FURRYe38
thank you for your advices.
I did an "out of the box" install after updating to the latest FW and I didn't work without "no response" in the Home App.
Downgrading from the latest FW to a FW that have almost 2 years old is not a solution to me, regarding security or general improvement.
I don't know what I will do now, maybe try to fine tune again RTS/CTS etc... to make it work, and wait for a FW correction from Netgear.
And if it don't come, I will probably change my system to a eero or a velop one.
Thank you again.
Have a nice day.
Philipe
Message 3 of 4
Guru
v16 is not two years old.
I recommend contact NG support and get additional help and information regarding this. Let them know what your having problems with.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 181 views
  • 0 kudos
  • 2 in conversation
Announcements
