- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK20
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBK20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK20
You can file a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
What kind of problems are you having?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK20
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@Boxbert wrote:
My Orbi satellite no longer connects to the router and I can’t see the Orbi in the wifi list to connect to it. Keeps going back to the modem for wifi connection.
