- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK23 - additional satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBK23 system that I"m going to setup. With another RBK23, will I be able to add the additional 1 or 2 satellites to it? If I go with an RBK30, can I use the satellite that plugs into the wall with the RBK23. How many satellites will the RBK23 support since it comes with 2 to start off and in what combination RBS20 or plug in ones?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK23 - additional satellites
Yes, the official max number of Satellites is 3, but few have reported that they used up to 5 or 6 Satellites with no problem.
Yes
The official max number of Satellites is 3, but few have reported that they used up to 5 or 6 Satellites with no problem. You can have RBS20 and/or RBW30 in any combination.
- Mark as New
- Bookmark
- Subscribe
- Permalink
30 feet is recommended in between the base router and satellites to begin with depending upon building materials.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What about an RBK50 with two of the satellites from the RBK23 (so two RBS20's). Would I be downgrading the performance of the RBK50 system though since the smaller RBS20's have the lesses backhauld bandwidth or would the RBK50 setup perform to specs with each other at least? And, what would be the best positioning of the RBK50 and RBK23 satellites in a 3 story house where they main router needs to be located in the basement. WIll probably run them in AP mode though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBS50 satellites connect at 1700Mb while RBS20s connect at 867Mb. If you Daisy Chain the 50s with each other, then they still connect at 1700Mb. 30 feet is recommended in between them to begin with depending upon building materials.
