Reply
RBK23 not connecting to TV or Orbi APP
Monty33
I've just run through the setup for the RBK23 with one router and two satellites.  It seems to be functioning perfectly on most devices, phones, pads etc.
The Orbi APP though continues to say "Orbi Network Not Found" even though I am connected to it on the device and using it without issue.
Secondary to this my LG TV says it is connected to the network but nothing will function through the device, NETFLIX, PRIME both saying there is an internet connectivity problem
I'm at a complete loss, can anyone help?
Message 1 of 3
Accepted Solutions
Monty33
Re: RBK23 not connecting to TV or Orbi APP
Thanks for the reply but I seem to have resolved it by turning off the wifi signal from the ISP router.
Message 3 of 3
All Replies
Guru
What modem/gateway is the orbi connected to?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Monty33
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 285 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
