- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK23 - sudden solid magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone,
I recently purchased the Orbi RBK23 to solve some wifi issues at home and it has been absolutley fantastic!
However, sadly when I came downstairs this morning, the ring on the router was a solid magenta.
I have tried all the obvious things, restarted both the Orbi router and my Telstra Cable modem but am having no luck at all.
As far as I'm aware it is running the most uptodate firmware.
Any help would be greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK23 - sudden solid magenta
Power OFF the ISP modem and RBR for 30 seconds. Then power ON the modem. Let it sync. Then power ON the RBR. Does the RBR top ring LED turn OFF or still remain PINK?
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks I'll give this all a go. As I mentioned, I've had absolutely no problems until this morning which makes it all a little more annoying!
- Mark as New
- Bookmark
- Subscribe
- Permalink
