Orbi WiFi 7 RBE973
Reply
RBK30 disconnecting
atomarchio
Tutor
RBK30 disconnecting
So I've owned the RBK30 for 2 years now and it's not working properly.
I've had to reboot the router each morning 3 of the past 4 days as all of my devices are no longer connected to the internet when I wake up.
Once I reboot the device things work fine but I have to do this almost daily.
Is there anything I can try to resolve the problem?  Or is it just time to buy a new router?
Please help.  Thanks.
Message 1 of 2
Guru
Re: RBK30 disconnecting
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 955 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
