Orbi WiFi 7 RBE973
Reply
RBK40 No longer works
chillpenguin
Initiate
I have the RBK40, NOT the RBK50, but Netgear's community software isn't aware of its existence.
I haven't had this thing for a week yet. It was fine over the weekend, but this morning I woke up to no wireless connection - the Orbi's SSID disappered. The router and the satellite only flashed white over and over.
When I returned home this evening I power cycled the router. I also held down the reset button (until it clicked) and powered on the unit. I also held down the reset button while it was on. The only change I ever saw was the power indicator turning red and flashing. I removed the push pin, and it went back to sold green. White LED still flashing.
I have no way to factory reset or even connect to this thing. No SSID is shown so I can't even log into it. Do I have a paperweight now?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: RBK40 No longer works
Hello Chillpenguin
We are aware of the issue with RBK40/30 and are working to fix the issue. Contact support they will be able to replace the unit if needed if it is bricked or help you recover the unit.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 3
chillpenguin
Initiate
Thanks for the info Darren, I appreciate the response.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2452 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
