Reply
RBK40 Orbi connectivity issues
icemagic17
Tutor
I have an ORBI RB40 I purchased last year.  It has been great, but in the last month I am having connectivity issues.  When I return home or restart a device, I need to turn off the wifi on the device and change betweent the guest network and regular network to get internet connection. I know the internet is not the problem, because I have connectivity on my phone or another device at the time.  I can hard wire the internet into my computer and get connection through ethernet cord run from the ORBI.  After taking maybe upto 5-10 minutes I will get connected and have no issues staying connected.  This is more of a hassle and nuisance than anything else.  I have in house cameras that are not as easy to reconnect to the wifi and would like to resolve the issue, rather than continue with the work around and hassle of getting connected.  Any and all help would be appreciated.
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 10
Accepted Solutions
Guru
Re: RBK40 Orbi connectivity issues
Ok, have her disable the wifi on the phone for about 10 seconds then back on, and also "forget this network" on the phone and then attempt to re-join.
Keep us posted.
@icemagic17 wrote:
I did those adjustments last night and had most devices connected. My wife said her phone didn’t connect in the morning before she left for work. I will check everything again tonight.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 8 of 10
All Replies
Guru
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Message 2 of 10
icemagic17
Tutor
Sorry amature hour here.  By FW is that the version? It is 2.2.1.210
Technicolor TC8305C
I believe the ORBI is in router mode, but am not sure how to double check and verify.
The house is about 3500 sq ft.
The satelites are within 20 ft of the main ORBI.  Almost directly above and below on separate floors.
I tried resetting the 5 ghz channel to 40 because no one else appeared to be using that one.  That didn't help at all.
I live in a standard neighborhood and when I pull up networks I would guess I can find over 10, some being from the same house as they are labeled guest network.
Security is WPA2-PSK
How do you enable MIMO and beanforming?
Message 3 of 10
Guru
@icemagic17 wrote:
Sorry amature hour here.  By FW is that the version? It is 2.2.1.210 YES
Technicolor TC8305C <This is a router and wifi modem combo:
https://www.router-reset.com/reset-manuals/Technicolor/TC8305C
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I believe the ORBI is in router mode, but am not sure how to double check and verify. Navigate to Advanced Tab/Advanced Settings\Router and AP mode.
The satelites are within 20 ft of the main ORBI.  Almost directly above and below on separate floors. 20 feet is too close between the base router and satellites. 30 feet is recommended in between them to begin with depending upon building materials.
Navigate to Advanced Tab/Advanced Settings\Wireless Settings
Message 4 of 10
icemagic17
Tutor
Thank you.  I had to head into work, but I will try these things when I get home tonight.
Message 5 of 10
Guru
Hope the suggestions help. Let us know how it goes...
Message 6 of 10
icemagic17
Tutor
Message 7 of 10
Guru
Keep us posted.
Message 8 of 10
icemagic17
Tutor
I made all of those changes and everything seems to be working well.  Thank you for the support and help.
Message 9 of 10
Guru
Enjoy. Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2467 views
  • 5 kudos
  • 2 in conversation
Announcements
