- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK40 can't reach Gigabit Internet speeds over PPPoE
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been trying for a few days now to get my Orbi RBK40 to reach the full speed of my fibre connection (1 Gigabit down, 960 up). I've tested the line using the modem provided by my ISP and it does reach that speed, so I know the issue is with the Orbi and not with the ISP or the wire.
I found some posts here that said I needed to do a full factory reset and make sure to skip the speed test, which I did but no luck. The fastest I can reach with the Orbi is around 600 up and down.
Does anyone know of another workaround or fix for this? Some forums I've read said the Orbis just can't do gigabit over PPPoE, but I'm not sure if that's true, or if I'm just missing something.
I'm running the latest firmware, and both the modem and my computer are connected via ethernet with WiFi turned off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK40 can't reach Gigabit Internet speeds over PPPoE
What FW is currently loaded?
Others are seeing similar issues on PPPoE:
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi is connected to a TP-link media converter which is using my ISP's SFP tranceiver and VLAN35.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is someting I would file a support ticket for and have NG connect debug logs from your system to review:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
