- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK40 upload movie on youtube by wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
The youtube upload speed through is extremely slow, it takes 70minutes for 1GB movie. But the speed test shows that the upload speed is 65Mb/s.
But when I use 4G mobile network to upload the same file, it takes 15 minutes only.
I also used wired LAN wire orbi netwoek to upload the movie, it take 2 minutes to complete uploading process.
Can you help to solve this issue???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK40 upload movie on youtube by wifi
What wireless device are you using to upload the file?
Which frequency is the device connected too? if 2.4ghz, might be why.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Set WPA2 and AES on the Orbi router and apply and reboot both router and satellite.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting that changing channels helps however only for the one upload then slows back down.
I think NG support needs to review this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
