Orbi WiFi 7 RBE973
Reply
RBK43S-100NAS not reaching full speed with AT&T
djdroent
i just upgraded my internet to fiber optic with At&t before i had a speed of 75 mbps but now the speed will only stay at 90 but when i connect direct to modem it get full speed i was on with support and they advised that the cable cat 5e can not reach those speeds that the cable needs to go to cat 6 ( which is a bogus excuse) can any one help
Message 1 of 4
Guru
Re: RBK43S-100NAS not reaching full speed with AT&T
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to...
ATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994...
ATT Dumb Swiith Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/h...
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/tr...
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
Message 2 of 4
djdroent
firmware V2.3.5.32
the model on att is a pace 5268acfxn
Message 3 of 4
Guru
I would configure the Orbi system for one of the options. I would try option #3 first. There seems to be problems with this model ISP modem and Orbi systems. Might ask your ISP for a more up to date modem model. I believe an Arris BGW210 model maybe something to ask about
You might also update FW to v16 as last resort:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/tru...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 559 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
