- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK43S firmware update seems to have crashed everything
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK43S firmware update seems to have crashed everything
DO NOT ATTEMPT TO EXTRACT THE .IMG files after unpacking them from the .zip file. Use use them in the TFTP program or with in the RBR or RBS web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SoNCSU95 wrote:
Haven’t had a problem in two years. Have tired everything.
It might help to explain the specific issues you are having with this RBK43S system
- When they started
- What devices are affected and how
Using TFTP is a 'desperation effort' after a lot of other remedies have failed and not one of the normal steps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
