Reply
RBK44-100NA Updates on the Max Number of Satellites
Privatebar
I have purchased the ORBI RBK44-100NA Whole home Wi-Fi system (8,000 Sq Ft) system. I have deployed with 3 satellites and they are just not enough for the size  /  construction of the home. The home is just over 10,000 Sq Ft and has alot of stone work. Looking for a updated answer to the max number of satellites. We would also like to place one in the pool/spa room and an additional one outside by the docks. I really need 5-6 satellites to make this work correctly. Please advise.  We are not gaming or streaming much at this time.
Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Guru
Re: RBK44-100NA Updates on the Max Number of Satellites
Others have mentioned having 6 satellites. That was on a 50 series. I presume the 40 series would work as well. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 6
Privatebar
WOW Only 30 feet between the devices. I have rooms that are over 40 feet.  Not sure how they can cover 8000 Sq Ft at 30 ft apart.  I really just want a solid solution that is consistent without the ups and downs.  Thank you for your response. I will try and add a few more satellites and see what happens.
I will provide details once I have tested.
Have a Super day.
Message 3 of 6
Guru
30 ft is the recommended starting distance. We've seen users post with distances beyond that. 50 and 60 feet.
Is this for a home?
Testing
Message 4 of 6
Privatebar
Yes this is in one home.
Message 5 of 6
Guru
Ok. Let us know how it turns out. Smiley Wink
Testing
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 635 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
