Reply
RBK50 Can't detect device, no internet, intermittent access???
DPL-OZ
All of a sudden after 6 months of perfect function my Orbi RBK50 hardly works?
I am in Sydney Australia and purchased this in April this year. MacOS setup, multiple devices connected, 2 Satellites - one an outdoor variety.
What happens now is that there are several connection issues:
1. Can't detect the device (Router RBK50) from the Ios App;
2. No Internet connection;
3. Intermittent access and then all of a sudden all the same issues return?
We have a mandated National Broadband Network (NBN) in OZ and that provides the actual Internet service to my home. That actually workes perfectley and I can connect to that system without a p[roblem. I use the Orbi system as a wi-fi extender throughout my home.
I have cycled the power to ALL devices, setup the whole system again and nothing changes?
Can anyone assist me??
Regards DPL
Message 1 of 12
Guru
Re: RBK50 Can't detect device, no internet, intermittent access???
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 12
DPL-OZ
When I could actually connect to the Router the Firmware was the latest version for non-USA.
Re size of home, we are metric so I have no idea what ft is? Nonetheless, I have 2 satellites and it all worked perfect before. The whole property had access over 700sqm.
As I can't connect / detect the router I have no way to answer your other questions and I cannot change any of the setup??.
Message 3 of 12
Guru
Ft = Square Feet.
Message 4 of 12
Guru
Try a factory reset and setup from scatch with a wired PC and web browser.
Message 5 of 12
DPL-OZ
I can't do a factory reset as I cannot connect to the router! I regret that I am also not sufficiently technical to understand the rest of your messages.
I don't work in feet so have no idea. Property is 700sqm and prior to last Friday I had perfect access all over the property including outside in the garden.
Message 6 of 12
DPL-OZ
I now believe "Mfr" means Manufacturer - I was not aware of that form of abreviation.
As I am in Australia, this information is likely to be of less use to you:
Mfr of modem = Telstra Smart Modem Gen2
Firmware is v2.5.2.4 - this is up-to-date for RBR50 outside of the USA
Circle is off and Anywhere access is disabled.
Does this assist?
Message 7 of 12
Guru
Do you not have a wired PC to connect to the back of the RBR?
Pressing the reset button in back of the RBR for 15 seconds then release, should result in accessing the RBRs setup wizard at 192.168.1.1 with a wired PC and web browser.
You might want to get additional help from a family member, friend or neighbor to help you out with this.
Message 8 of 12
DPL-OZ
Thank you so much for your assistance. I do not have a PC only Mac - will that work if I connect via an Ethernet port??
Message 9 of 12
Guru
Yes.
Your modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 10 of 12
DPL-OZ
Thanks again - I am no longer capable of doing this. I used to be years ago but have had to move to running international businesses and let more of my tech capabilities go.
The double NAT setup is not optional for us in OZ as far as I understand. I have to have this under the NBN and then apply wifi extenders over the top of this.
What I don't understand is why/how this was working fine until last Friday? Nothing has changed.
kindest regards
dpl
Message 11 of 12
Guru
I recommend contacting your regional NetGear support site or have a friend, family member or neighbor help you out.
Good Luck.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 460 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
