- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 Firmware Version 2.5.2.4?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 Firmware Version 2.5.2.4?
Release notes finally now available for 2.5.2.4 here:
RBR50 / RBS50 Firmware Version 2.5.2.4 | Answer | NETGEAR Support
- Fixes the issue where the Nintendo switch failed to connect to the Internet after the Orbi installation due to IP conflicts.
- Fixes the system stability issues that occurred after the firmware updated to v2.5.1.32.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Thank you for letting us know.
Enjoy.
@jijun1964 wrote:
I just update firmware 2.5.2.4 foe RBS50 and RBR50. Smoothly update and running. Stable, and all device connected has been show properly. It so long long waiting for firmware running as expected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: RBK50 Firmware Version 2.5.2.4?
I installed 2.5.2.4 yesterday and have had some wifi drops and a lot of connected devices are not showing as connected.
Also tmy satellite doesn't show device name just "unknown"
Any one else having these issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a power off for 1 minute then back on been performed since last update?
@Almighty wrote:I installed 2.5.2.4 yesterday and have had some wifi drops and a lot of connected devices are not showing as connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Powered it down for approx 5 min.
Still missing a lot of devices and all devices on the satellite are "Unknown"
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Almighty wrote:Yes. Powered it down for approx 5 min.
Those are the ones that you will probably have to go to directly and forget the network and re-join, then reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also update the firmware to the latest 2.7.0.70
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have restarted a couple of devices but they are not shown in connected list.
Also none of the wires devices are showing either.
A lot of wifi devices are dropping connection.
The firmware updates of Orbi RBR50 is really bad.
It shouldn't be this many issues every time a new FW is released.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update the firmware to the latest 2.7.0.70
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to power OFF the ISP modem, RBR and RBS for 1 minute then back ON after a FW update. If problems still crop up, a factory reset and setup from scratch maybe needed.
@Almighty wrote:I have restarted a couple of devices but they are not shown in connected list.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How the hell can a restart of my fiber switch have anything to do with my Orbi not showing my connected devices?
If I reboot/shutdown the Orbi units all connections are dropped and the Orbi router has no idea if any other node has been restarted.
But just for taking your advise I will do as you what you say.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have now shut down evrything. Fiber switch, router, satellite, all switches.
Still having issues with not showing connected devices. But the worst is that devices drop wifi connection.
Really thinking of getting another mesh system. I have never seen a system with this much issues for every FW upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgrade to v16. I haven't had any problems with v16 and wireless connections.
@Almighty wrote:Have now shut down evrything. Fiber switch, router, satellite, all switches.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgraded to .16 and it looks much better.
So once again Netgear has released.a crap FW version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same here the solution is downgrade firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yup, badly borked - the connected device page is completely inaccurate. Logging into the satellites shows local connections, but even those are incomplete.
Downgrading to 2.5.1.16 is the answer.
Netgear *really* needs to give us a UI option to disable firmware updates that persists across reboots.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@COMountainGoat wrote:Yup, badly borked - the connected device page is completely inaccurate. Logging into the satellites shows local connections, but even those are incomplete.
Actualy if you wait 24 to 48 hours, the system seems to stablize and everything seems to correct itself in the app and GUI, with the exception of maybe a cellphone and camera or 2, which just needs to have the network forget and rejoin routine.
Problem is everyone is impatient and downgrades too quickly.
The better solution would be to manually upgrade to V2.7.0.77. Just remember to update the satellites first, then the router. I upgraded 3 RBK53 systems this morning to 2.7.0.77, with no issues.
I find, after updating, I see better speeds on any ISP over 350Mbps and smoother and faster connections.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I waited three days and it didn't get better.
Downgrade is the only solution that has worked for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found same thing happens with v4 as well as v70:
v16 seems to work the best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even if waiting worked (which from other reports, it doesn't), waiting hours or days for a network appliance to correctly report attached devices isn't acceptable. Full Stop.
It appears that the SDLC for Orbi Firmware consists of:
1) Does it compile? Yes -> Ship it
With little to no QA or regression testing. Seriously, something as basic as attached devices breaking wasn't caught?
If the radio's weren't so darn good, I'd dump the system. As it is I'm very tempted to blackhole the Netgear update servers so it can't ever auto-update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Users can revert to v16. v16 seems to work well for stock FW. Havn't had any problems using this version.
User can also use Voxe's 3rd party FW as well:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
Good Luck
