- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 Intermitent Wi-Fi issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last year I bought a RBR50/ RBS50 Router/ Mesh Kit from Amazon (the RBK50 kit). I decided to update the firmware last year and the result was intermitent wi-fi from the RBR50. I have tried all the possible versions of firmware, through from RBR50-V1.4.0.34 to the most recent RBR50-V2.5.1.16 (always taking care to load the same version of firmware on the RBS50). The problem persists. The wi-fi comes and goes for no reason. I have set it up as the main router, since my local Broad Band provider's router does not give me all the necessary controls.
As the RBR50's wi-fi comes and goes, so does the connectivity with the RBS50 Satelite.
I have configured the RBR50 with a 10.0.0.1 base DHCP address, have set up both the 2.4 and 5 Ghz wi-fi networks one single SSD, have tried automatic channels and have set the channels to fixed channels 02 (for 2.4 GHz) and 36 (for 5 GHz). Have not turned on Fast Roaming or Mu-Mi.
I do have V2.5.1.16 firmware loaded on both devices at the moment. But am getting ready to put the pair of Orbis back in the box and stop wasting my time on this.
If anyone can give me any suggestions, they would be very welcome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 Intermitent Wi-Fi issues
By the way, on a wired connection I get very good speed, up to the nominal 240 Mbps downoad and 20 Mbps upload
@ajbacon wrote:Last year I bought a RBR50/ RBS50 Router/ Mesh Kit from Amazon (the RBK50 kit). I decided to update the firmware last year and the result was intermitent wi-fi from the RBR50. I have tried all the possible versions of firmware, through from RBR50-V1.4.0.34 to the most recent RBR50-V2.5.1.16 (always taking care to load the same version of firmware on the RBS50). The problem persists. The wi-fi comes and goes for no reason. I have set it up as the main router, since my local Broad Band provider's router does not give me all the necessary controls.
which I contracted from my Broadband provider.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting manual channel 1, 6 or 11 on 2.4Ghz. 2 should not be used.
