- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 Orbi AC3000 compatibility
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 Orbi AC3000 compatibility
Please post about this over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check with your modem and ISP services first.
Check speeds with a wired PC directly connected to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Factory reset the RBR and setup from scratch. Do not enable Armor, Circle or Traffic Meter.
