- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 Orbi Router- Wifi pw does not show correctly in web interface or Genie app after firmware upgr
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have used an 11 character wifi password that includes 2 special characters. No issues until a recent firmware upgrade to the 2.1.1.12 version. I had missed several firmeware versions since the update check button did not show anything available. I upgraded router and sattellites manually.
When router reset, only the wired devices reconnected. I checked settings and the wifi password appeard to have been reset to something I used over 8 months ago (probably original one I set). I changed it but it seemed to then show on web interface and in Genie app as something a little different from what I had entered. After a few tries, most (25) of my wireless devices reconnected (2 dlink smart plugs did not). But when I checked the web interface and the Genie app, the wifi password that shows up is only 8 characters long. It shows the first 7 characters correctly and then the 11th character correctly (happens to be a special character). So the wifi password being used seems to be correct (11 characters that all devices were set up with ) but what shows in the web interface and Genie app is an 8 character password.
This device is at a remote location so I am somewhat limited right now in doing anything other than via the web interface or the Genie App.
Thanks in advance for any guidance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 Orbi Router- Wifi pw does not show correctly in web interface or Genie app after firmwa...
I know there are some issues with spaces being in passwords and $ signs we are going to fix those in the next firmware.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would it be possible for Netgear to be a little more up-front about what bugs it's tracking here, priorities and any expectations on updates? Lots of issues being reported, but no real feedback from Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
