Reply
RBK50 ROUTER CANNOT CONNECT TO INTERNET WITH CURRENT SETTINGS
oola
My Orbi stopped working couple of days ago and I have reset it to factory settings but that has not made any difference. Please see below the error message I recieved : THE ORBI ROUTER CONNOT CONNECT TO THE INTERNET WITH THE CURRENT SETTINGS .
I have the latest firmware installed which is
RBR50 (Orbi Router) Firmware Version 2.2.1.210.
Any help would be appreciated .
Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Guru
Re: RBK50 ROUTER CANNOT CONNECT TO INTERNET WITH CURRENT SETTINGS
Try a factory reset and walk thru the setup wizard.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 6
DickDuke
Apprentice
You probably did this before posting here, but if you haven’t...
Turn off or unplug from power your Orbi AND your Internet modem.
wait a few seconds, then turn them on again.
wait another few minutes, then check for Internet again.
most ISPs change the IP addresses that they assign to their modems every few days or so. Sometimes a home router will keep using the old, no longer valid address, the simple off & on just forces everything to refresh with the same IP.
RBR40 + (2)RBS20 + RBS30W
Message 3 of 6
oola
Thanks for your help guys, It has happens that my internet connection require a login in the router internet setup and I changed it to Point-to-Point Protocol over Ethernet (PPPoE), enter the user name and password that from my ISP Provider and set connection mode to ALWAYS ON and apply the settings and it worked.
Message 4 of 6
oola
Message 5 of 6
Guru
Glad you got it working.
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1187 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
