- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 - Router Light Ring Pulses White And Internet Drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi everyone, for the past few months I have been having issues with my RBK50. For some reason, the light ring pulses white for about a minute and the internet drops and then restores like nothing happened. I am not sure what is causing this and I woul appreciate any help anyone can give me. The problem only lasts for about a minute. I am running firmware version 2.1.2.18. Has anyone else had similar issues with this model?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBK50 - Router Light Ring Pulses White And Internet Drops
.18 has reported problems
you may want to fall back to .14
Call Netgear support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What is the Mfr and model of the ISP modem? Buillt in router by chance?
As VAJim suggested, you might revert back to v2.0.1.4. Use IE11 or FF browser to send the file. Factory reset both Router and Satellites. Set up the Orbi router first.
Set Manual channel to 1, 6 or 11
Set WPA2 and AES only.
Disable 20/40Mhz Coexistence
Disable Beamforming and MIMO, Daisy chaing and Fast Roaming if any of these are available after downgrading.
@anthony17wrote:Hi everyone, for the past few months I have been having issues with my RBK50. For some reason, the light ring pulses white for about a minute and the internet drops and then restores like nothing happened. I am not sure what is causing this and I woul appreciate any help anyone can give me. The problem only lasts for about a minute. I am running firmware version 2.1.2.18. Has anyone else had similar issues with this model?
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am having the exact same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What version of FW are you using? If v.18 then you might want to revert back to v2.0.1.4.
