Reply
RBK50 Satellite Speed
meach13
Initiate
Hi Everyone,
New to the forum and did a little searching.  Does Orbi software have or do they plan to add speed between Satellites?  I do show it is on 5g but not the actually connection speed between the 2 Orbi.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Guru
Re: RBK50 Satellite Speed
No idea, you can made a request here for it:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
The speed rates should be at max per the specs seen for the 40 or 50 series.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK853 (Router Mode) | and R9000 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 4
meach13
Initiate
Thanks,
It would just be easier to be able to find tune the placement of the satelitte.  Right now I am getting around 100 meg but every blue moon it will get around 280.
I will put a request in.
Message 3 of 4
Guru
I agree, would be more helpful.
Another app I find helpful for devices with wifi is WiFi Sweet Spot. It's tests the connection between the device and router or satellite.
Generally, check the routers web page for the status of the connection between the router and satllite. 30feet is a good start, not too close. Mines 40 feet.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1049 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
