Orbi WiFi 7 RBE973
Reply
RBK50 Unable to use Orbi Traffic Meter feature to round up data by coonnection
RickJo
How does one get to and use the check box and Traffic Meter feature described as "Round up data volume for each connection by"?  It seems in accessible and unusable to me.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Guru
Re: RBK50 Unable to use Orbi Traffic Meter feature to round up data by coonnection
This feature maybe something that hasn't been fully enabled by NG in the FW.
What version of FW are you using currently?
Message 2 of 4
RickJo
My firmware:
 Model NameDevice NameCurrent VersionStatus
RouterRBR50RBR50V2.1.2.18No new firmware version available.
Message 3 of 4
Guru
This is sometihng I don't see with my router. I'm on a beta just up from v.18. Not sure if this is a feature that has been removed or will be or only seen on certain modem Orbi systems.
You might contact NG support and ask about this...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1665 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
