- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 dropping connection to fiber optic network
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 dropping connection to fiber optic network
While connected to the ISP system, do a factory reset and walk thru the setup wizard. Be sure to write down important information for safe keeping later. Set up the router from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Ensure the ISP checks the signal level at the router and there Fiber ONT box if there is one some place.
