- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 drops to 30Mbps every couple of hours, must reboot to fix
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just installed RBK50 Orbi Triband Mesh AC3000 system and after a few hours, the speeds drop to below 50 Mbps and the only thing I can do to fix is reboot. I've now rebooted my system 5 times in 24 hours. I'm running the latest firmware 2.5.1.8 and Netgear support had me set the MTU to 1492. It was set at 1500. Right after a reboot and for a few hours after I can get close to 600Mbps on my phone (Galaxy S10). Then it drops back down below 50Mbps after 2-3 hours. Anyone see this before and have a fix? Not sure what's happening to make it suddenly lose speed like that. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 drops to 30Mbps every couple of hours, must reboot to fix
@whynotme wrote:Just installed RBK50 Orbi Triband Mesh AC3000 system and after a few hours, the speeds drop to below 50 Mbps and the only thing I can do to fix is reboot. I've now rebooted my system 5 times in 24 hours. I'm running the latest firmware 2.5.1.8 and Netgear support had me set the MTU to 1492. It was set at 1500. Right after a reboot and for a few hours after I can get close to 600Mbps on my phone (Galaxy S10). Then it drops back down below 50Mbps after 2-3 hours. Anyone see this before and have a fix? Not sure what's happening to make it suddenly lose speed like that. Thanks in advance.
I'm going to bet the FW 2.5.1.8 is your problem. When/how did you get it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It updated automatically when I installed the system yesterday.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should add that I'm running a brand new CM1150V modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've see discussions about your modem.
Just in case...https://www.netgear.com/support/product/CM1150V.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? I would do this if you haven't.
Set the MTU value back to 1500, 1492 or less is for DSL ISP services. Cable services use 1500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the size of your home? Sq Ft?
