- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 ethernet port only 100mps
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I have the RBK50 router connected to sprectrum modem (not wifi modem). i have spectrum 400mps speed. wirless out of Orbi gets 400-450mps all day long. problem is my ethernet ports only allowing 100mps best..usally 90-100mps range. i have used cat 5e, cat 6, different computers, tvs, etc and no matter what these are max speeds i get.
appreciate any insights
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok...didn't understand 😬
lomg story short....all pots allows up to 1gb. Problem is apparently all TVs typically have 10/100 Ethernet , and turns out my laptop also has same. When I connected my Orbi satellite via Ethernet...it was pulling the 400+MBs speeds.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 ethernet port only 100mps
@kmh7189 wrote:So I have the RBK50 router connected to sprectrum modem (not wifi modem). i have spectrum 400mps speed. wirless out of Orbi gets 400-450mps all day long. problem is my ethernet ports only allowing 100mps best..usally 90-100mps range. i have used cat 5e, cat 6, different computers, tvs, etc and no matter what these are max speeds i get.
Very strange indeed. What connection rate shows up on the Orbi web interface, Advanced Tab Home Page, click on "Show Statistics"?
How is the speed being measured?
- Mark as New
- Bookmark
- Subscribe
- Permalink
getting 446mps dowonload. so i have to find a device that has a gigabyte ethernet port. seems like tvs only support 10/100.
- Mark as New
- Bookmark
- Subscribe
- Permalink
v2.5.1.8 updated last week is installed. i have T470 Lenovo that has 10/100/1GB ethernet port. hooked directly to orbi router port and all i get is around 100mbs. makes no sense.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
it downloaded and then installed...notice on my app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you manualy load older firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the screen shot. Looks like LAN1 should support higher speed, while LAN3 will not.
This is another time when I wish Netgear had numbered the ports 1, 2, 3 so we would know which one we are using without having to pull the cable out and see which one disappears.
If the computer is attached to the 1000mb port, then it certainly should get more than 100mb.
Speed is being measured with something like speedtest.net or fast.com?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes online speed test sites..tried them all same results. i dont understand why one port puts out 1G but 2 dont? stupid. im going to hook computer to all 3 ports and see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so i hooked computer to all 3 lan ports.....nothing more than 100mbs speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@kmh7189 wrote:so i hooked computer to all 3 lan ports.....nothing more than 100mbs speed.
Thanks for experimenting. I don't suppose you noticed if the 1000mb connection "moved with" the computer? i.e. I'm pretty certain that "port 2" is in the middle (between port 1 and port 3). I just don't know which side port 1 is on. So, when the computer was iin Port 2, that was the port that reported 1000mb?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i dont know either. i just presume in order so it goes LAN, 1,2,3
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is connected to the port that reports 100mb?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This maybe a HW issue, not a FW issue.
Try a factory reset on the RBR and setup from scratch. if this fails to correctly the speed rate, you may want to get the RBR replaced if after troubleshooting everything.
@kmh7189 wrote:yes online speed test sites..tried them all same results. i dont understand why one port puts out 1G but 2 dont? stupid. im going to hook computer to all 3 ports and see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:This maybe a HW issue, not a FW issue.
wrong....how can you keep saying this? You are a part of the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm part of problem?.. anyway....
Resolved ....not hardware issue.
peace out
- Mark as New
- Bookmark
- Subscribe
- Permalink
