Reply
RBK50 repeatedly dropped internet after Firmware update a few days ago
lwhi021
Follower
My Orbi is connected to a Huawei HG659 modem wifi on that is off and all device connections and DHCP allocation are via the Orbi. I have had the system for some time now and it has been relaible and stable.
After a firmware update a few days ago I kept loosing my internet connection which I deduced was a result of the DNS server settings getting corrupted in the HG659 modem.
I spent 2 very frustrating days trying various things to get my system stable again. Ultimately I think I stumbled on the solution by accident. I plugged my laptop in to the HG659 after the internet connection failed  as I wanted to check the settings on the HG659. To my surprise the internet connection started to work again. I think that by having an internet connected device attached directly  to the HG659 it is able to manitain that connection properly. I subsequently connected a TV set top box to the HG659 and have not had a problem since.
While I believe I no longer have a problem I don't understand the technicalities that may be behind the original problem
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Guru
Re: RBK50 repeatedly dropped internet after Firmware update a few days ago
If your modem has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first, or #3...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 3
vajim
Master
Your answer is in your subject line
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 127 views
  • 0 kudos
  • 3 in conversation
Announcements
