Reply
RBK50 seemingly dead?
DavidShawP
Star
I’ve got an RBK50 with three satellites. It’s worked fine for years but tonight it isn’t responding. When I reboot it the ring light never comes on.
I tried resetting by inserting a paper clip with it powered on but the power button light just stays green and never turns amber. Help!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: RBK50 seemingly dead?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
DavidShawP
Star
I appreciate the feedback.  I tried both methods.  It seems it's too dead even for these low level tools.
./nmrpflash -i en0 -f RBR50-V2.7.3.22.img
Advertising NMRP server on en0 ... |
No response after 60 seconds. Bailing out.
I guess I have to go buy a new router.
Message 3 of 4
Guru
Sometimes it can take a few tries to get the timing right.
Another thing you can try doing is swap the power supply from the router with a satellite. Maybe its going bad and not supplying enough power to boot the router.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 401 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
