- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50 - two firmware versions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why are there two firmware versions for the RBK50 and which one should be used?
Edit: screenshot doesn't seem to be working but the versions are 2.7.1.104 and 2.6.1.40.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, two versions, and no explanation why. Isn't it a hoot!
There is an urban legend that the 2.6 firmware might be intended (a) for world wide rather than US, or (b) for customers who prefer to remain with Disney Circle rather than migrate to the new Netgear Patental Controls. At one point, one of the versrions was labelled "U.S. Only", but that comment has disappeared. Netgear provides NO EXPLANATION.
So, what are customers supposed to do?
- One school of thought is, "if it ain't broke, don't fix it." We see posts every day that start off with, "updated Orbi firmware and now....(something horrible happened)." All these "security fixes" seem focussed on the LAN side of the Orbi, not on security breaches from the Internet.
- Another school of thought is, "If a security fix is serious, Netgear will push new firmware." During the origiinal setup, users have to click "ok" to the statement, "i realize that Netgear may push firmware updates to my system." Then let Netgear do what they said they'd do.
- There are some of us who think, "what the heck, it new firmware does something bad, I will just reinstall the firmware I had before." No Biggie. I am on 2.7.2.104. Had some hiccups and did a factory reset. Now all good.
You wanted answers. Sorry.
p.s. images posted "in-line" using the Photo icon do not appear until a forum moderator approves them, which can take hours. Images attached with the "Browse" button appear immediately.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50 - two firmware versions?
CrimpOn, yet you love your Orbi? j/k
Thanks for the response. I just upgraded to v.104 and am having issues. Went back to v.102 and having the same issues. Going to go to v.104 and do a factory reset *fingers crossed*.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@shobuddy wrote:CrimpOn, yet you love your Orbi? j/k
Back in 2016, I got tired of complaints, "WiFi sucks when I sit here." Tried saying, "Then, don't sit there." Not my best move.
Bought the Orbi and have strong WiFi everywhere, including three patios. Never goes down. Eventually I will have devices that are compatible with WiFi6 or WiFi6E and will have to consider if the cost of replacing the Orbi is worth it.
Factory Reset has the benefit of clearing out the cobwebs. Orbi remembers every device that has ever connected. When I updated to 2.7.2.104 sort of by accident, some devices worked, but did not show up in Attached Devices. Orbi stubbornly reported tham as "Allowed devices that are not connected." After a save configuration, factory reset, and reload configuration, they all appear correctly. A Factory Reset plus manual reconfiguration would have cleared out all those previous devices and God knows what other junk is hanging around in the Orbi firmware. I would have done the complete "clean house" if those devices had remained "unattached."
p.s. That "accident" was mefooling around inside the Orbi directories with telnet and erasing some key parts of the web interface. I had to manually load firmware, so I thought, "what the heck. Let's give 2.7.2.104 a try."
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is my first Netgear device in long long time and I agree that when it works, it works. That said, I find the app and web interface to be slow, clunky and leaves something to be desired. I've only had the RBK50 for a few months now and while its nice that it receives consistent updates, I've never had a smooth update process. To me it seems that the hardware is good but the software is average at best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two versions of each - one is for the router and the other is for the paired satellite.
Some firmware versions do not work/are incompatible with certain ISP systems.
For example: If you purchased your Orbi system from an ISP, they will have their own choice in which firmware to run on the system and will remote update for you. This is common in the cable modem systems; the Orbi environment can be created in a similar fashion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Shadowchasr wrote:Some firmware versions do not work/are incompatible with certain ISP systems.
There is no evidence of Orbi firmware being incompatible with certain ISP systems. The release notes contain no mention of this. The original post was asking about why Netgear posts two different firmware releases for the Orbi and gives no indication how a user should decide which to install.
@Shadowchasr wrote:For example: If you purchased your Orbi system from an ISP, they will have their own choice in which firmware to run on the system and will remote update for you. This is common in the cable modem systems; the Orbi environment can be created in a similar fashion.
This is totally incorrect. For cable modems, this is an inherent part of the design. ISP's totally control the firmware on cable modems.
But not on routers, and certainly not on the Orbi product.
There is one glaring anomoly: the Verizon branded Orbi. Some years ago, Verizon offered customers "a great deal" on Orbi WiFi, with a promise to keep the firmware up-to-date, and has never issued a firmware update. Not only that, but the firmware is "locked" and cannot be converted to Netgear firmware. People who got suckered by Verizon are stuck.
