- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50V vs RBK50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I bought Oribi RBK50V hoping it is comparable to RBK50 with $100 less. It seems satelite in RBK50v has lower backhaul speed, and also wired connection speed limit of 100 MB/sec. I was hoping that Orbi mess will give better coverage and speed compared to my Xfinity ARRIS Modem-with-router. But I do not see much difference.
Couple of thing I noticed were - (i) if I was 7 feets away from satelite and 25 feets away from router, it connected to router on 2.4 GHz channel. (ii) I was hoping better speed when wired to satelite, but it was other way around. (iii) you cannot disable or give different name to 2.4 GHz channel (ARRISS modem-with-router allows that).
I feel like satelite in RBK50v is lower capacity/range and almost useless. Should I spend $100 mre and go with RBK50 instead, so I do not need to worry if I am connect to router or satelite?
Appreciate all responses.
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can change the preample to long and try.
How far is the patio form the RBR or the RBS?
Yes, the RBS40v will have a lower wireless backhaul rate of 866Mpbs. Thought should be good for normal usage and performance.
WMM should be already enabled...just checking.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50V vs RBK50
The RBS40v's back haul is only rated at 866Mpbs. While the RBS50 is rated at 1733Mpbs. This all depends on distance, placement and building materials that can impact the connection rate seen between the RBS and RBR.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s)
Orbi systesm to not allow or support the separation of SSID name. These are wifi MESH systems which differ from non MESH wifi routers which don't have satellite devices that work in concert with the Orbi base router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50V vs RBK50
2.4 GHz: 802.11 g,n - Channel # 1, 20 MHz
5 GHz: 802.11 a,n,ac - Channel # 36, 40 MHz
Router RBR50 - Firmware version: V2.5.1.16
Satellite RBS40V - Firmware version: V2.5.1.2
ADVANCED -> Setup -> Wireless Setup
2.4 GHz Channel: 6
5 GHZ Channel: 44
Security Option: WPA2-PSK
Enable 20/40 MHz Coexistence: Unchecked
Preamble Mode: Short Preamble
Enable Daisy Chain Topology: unchecked
Enable Implicit BEAMFORMING: checked
Enable MU-MIMO: unchecked
Enable Fast Roaming: unchecked
IPv6: Disabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
