- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK50v2 Configuration
- Mark as New
- Bookmark
- Subscribe
- Permalink
Full context...(jump to c. for netgear specific question)
Hello all,
Trying to maximize the efficiency of a newly-acquired router from ATT (the IFWA40) that we received to replace our outdated Z700a. Based on some research, it supports a few more bands than the older device, hoping to get better connection speeds. I have a few things i'm trying to figure out...
a.) The IFWA-40 seems very inconsistent. We are in a very rural part of northeast Pennsylvania, so congestion wouldn't be an issue. We're on a grandfathered unlimited plus plan, so overages aren't much of a concern. I'm ranging from 100mbps to 25mbps down, a pretty steep difference. Time of day doesn't seem to matter much. Based on some calculations, tower eNB ID 22192 is about ~3 miles away, give or take .5 miles. It's not a 'direct' line of sight, but there isn't much in the way of forestry or buildings in the way. I moved the router to our south-facing sunroom, closest to the tower, on top of a cabinet and got a much better signal from more towards the center of the house, but again, speedtests are fairly inconsistent. ATT router GUI shows 4 bars of LTE at -97 dBm signal strength. Oddly, if my Pixel 5 ATT cell connects to the same tower (from the center of the house), the cell is getting -113 dBm but with 133mbps down (!!!). I'm no expert in 4G/LTE/5G connectivity, but I find that difference pretty shocking. How is that possible?
b.) Wondering if an antenna would help. I'm pretty much looking for any/all recommendations.
c.) Trying to figure out how best to set up my IFWA-40 / RBK50v2 Netgear Orbi. From what I can tell, there's no bridge mode option for the IFWA-40, so I figured I'd just set the ATT router IP to 192.168.1.1, turn off DHCP, set the Orbi Router to 192.168.1.2 and set the DHCP pool to start at 192.168.1.10 (as to leave room for some static IPs, pcs, consoles, etc.) However, with that config I couldn't get the Orbi to receive internet to save my life. I could connect to it fine, the ATT router was receiving internet, but no dice.
So I disabled DHCP on the Orbi, kept the same IP, and instead of running IFWA40 WAN to orbi WAN, ran the ethernet from IFWA40 WAN to ORBI LAN and just let the ATT router handle DHCP requests and have the IFWA40/ORBI run their own wifis. However...I seem to have a heck of time getting good connections to the Orbi's. ANYTHING that is connected to the Orbis, whether through ethernet or wifi, is drastically slower than connected directly to the IFWA40's wifi/ethernet. I can't seem to find out why.
So, I guess i'm wondering what might be the best practice for this kind of setup. I would prefer to just use the Orbi's mesh wifi system with one router and one satellite, but I'm not sure of the optimal configurations...
Any tips, suggestions, or insults in my setup would be greatly appreciated...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK50v2 Configuration
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #3 first...
- Mark as New
- Bookmark
- Subscribe
- Permalink
maybe this will help with your ISP modem
https://www.att.com/device-support/article/wireless/KM1336600/ATT/ATTIFWA40
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mavvie wrote:c.) Trying to figure out how best to set up my IFWA-40 / RBK50v2 Netgear Orbi. From what I can tell, there's no bridge mode option for the IFWA-40, so I figured I'd just set the ATT router IP to 192.168.1.1, turn off DHCP, set the Orbi Router to 192.168.1.2 and set the DHCP pool to start at 192.168.1.10 (as to leave room for some static IPs, pcs, consoles, etc.) However, with that config I couldn't get the Orbi to receive internet to save my life. I could connect to it fine, the ATT router was receiving internet, but no dice.
This can never work. With the Orbi in router mode, the LAN side has to be a different subnet than the WAN side. i.e. the DHCP pool cannot include any part of 192.168.1.x. That is why the Orbi is confused.
@Mavvie wrote:So I disabled DHCP on the Orbi, kept the same IP, and instead of running IFWA40 WAN to orbi WAN, ran the ethernet from IFWA40 WAN to ORBI LAN and just let the ATT router handle DHCP requests and have the IFWA40/ORBI run their own wifis. However...I seem to have a heck of time getting good connections to the Orbi's. ANYTHING that is connected to the Orbis, whether through ethernet or wifi, is drastically slower than connected directly to the IFWA40's wifi/ethernet. I can't seem to find out why..
This also cannot work. Orbi must be connected using the WAN port.
There are two obvious solutions:
- Reset the Orbi back to its original configuration (router mode with DHCP on) and connect the WAN (yellow) port to the ATT.
The Orbi will get whatever IP address the ATT gives it and be happy.
Connect everything to the Orbi.
As @FURRYe38 pointed out, this is a classic "Double NAT" situation which works fine 99.9% of the time. There are specific applications which cannot function in this environment, such as port forwarding, VPN (into the Orbi LAN from internet), and some internet gaming. https://kb.netgear.com/30186/What-is-Double-NAT Thousands of customers just "Plug in their new WiFi router" and never notice anything wrong. - If this should become a problem, then the Orbi can be put into Access Point (AP) mode and the AT&T will handle all DHCP work.
Most people would recommend disabling the ATT WiFi to avoid WiFi conflicts. WiFi is really tolerant of interference and with no close-by neighbors and not much internet bandwidth, you may never notice a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As for the ATT unit: Yes, external antennas are a common solution. Search for "IFWA40 antenna" will turn up many. The key is to be outside, facing the desired tower and as high as practical. I found this discussion fascinating:
