Orbi WiFi 7 RBE973
Reply
RBK53 Setup and Issues
Thalador
Apprentice
Hey all - I posted this yesterday but it seems to have been removed. Hopefully this sticks and I can get some help
I bought the RBK53 3 pack at Costco based on reviews and a lot of research. My house is only about 3k square feet but I have some dead spots plus the Costco return policy. So, anyway.
I am an IT guy with 30 years of systems experience so setting this up was simple. I disabled radio on my AT&T router (I have Gig internet at the house, up and down). Set up the Orbi router and 2 satellites and was on my way. Prior to this I did speed tests on my iPhone connected to my AT&T router. Once I got the Orbi setup I did a speedtest. Results were mixed. Noticed there was a firmware update available so did that and rebooted and retested. Here were the results
Location DL-AT&T UL-AT&T DL-Orbi Old FW UL-Orbi Old FW DL-Orbi New FW UL-Orbi New FW
At the router 458Mbps 478Mbps 304Mbps 311Mbps 230Mbps 210Mbps
Office 285Mbps 118Mbps 293Mbps 358Mbps 469Mbps 460Mbps
Living Room 407Mbps 202Mbps 426Mbps 438Mbps 375Mbps 345Mbps
Outside Deck 8.41Mbps 2.42Mbps 2.08Mbps .13Mbps 57.8Mbps 47.4Mbps
Sorry about the bad table, formatting is not working well. As you can see, after firmware some things improved while others got worse. I also ran a speedtest via orbilogin.net and it was showing as 500Mbps down and 930Mbps upload. So I called Netgear tech support. They had me factory reset and redo the whole setup. Download speed is still about 1/2 the upload speed, even on speedtest.net I was on the phone with them for 105 minutes and got nowhere. They were willing to "Check to see" if he could get an escalation to level 2 authorized but I wasn't willing to wait anymore. It's my birthday and my kids were making me dinner.
Is there something I am completely missing here that would cause DL speeds to be so bad? I enabled IP Passthrough on my AT&T router and disabled the wifi on it completely.
Any idea would be appreciated. I told the support guy if this is just not going to work then I can bring it back to Costco, but I imagine it is something stupid I can check,or uncheck.
Thanks!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Retired_Member
Not applicable
Re: RBK53 Setup and Issues
If you don't need the AT&T router, get rid of it.
Message 2 of 5
Guru
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thanks!
Message 3 of 5
Thalador
Apprentice
Thank you for the suggestions. I have an Arris BGW210 with AT&T which does not offer a true bridge mode. I have followed AT&T Forum Post and followed the directions stated to put it in IP passthrough mode. Is there something else to try with this? Is there a special setting on the Orbi I need to do to put it into router mode?
Message 4 of 5
Guru
IP Pass-thru mode should work for the Orbi if you run it in router mode. Nothing else would be needed here. Orbi runs in router mode as it's default mode.
Seen various users with some issues with this model modem. Some have resorted to using the modem in router mode and configuring the Orbi RBR for AP mode...
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 818 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
