Orbi WiFi 7 RBE973
Reply
RBK53 Software Update
Billy1956
Follower
My Iphone and Ipad keep wanting me to update to 2.7.0.70. The web interface says that no updates availabe.. Support says 2.7.1.60 for Router and 2.7.0.70 for Sattelites. I am currently on 2.5.2.4. I'm confused. I want to make sure I have the security fixes but I do not use Armor or Parental Controls.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
vajim
Master
Re: RBK53 Software Update
Forget the app
if you must update go with the pc login but stand by for  possible headaches
if your network is working with no problems then the question becomes why update?  Keep in mind netgear pushes security updates when you need them
Message 2 of 4
Guru
v40 is next version after v4 that you have loaded.
Any v2.7.x versions that you see are for US region users only.
v102 of the v2.7 line is most current and is avaialble for those in the US region who wish to update. Users can manually update directly to it:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2034115/high...
Using these proceedures:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
Update the RBS first then RBR lastly.
Good Luck.
Message 3 of 4
vajim
Master
@vajim wrote:
Forget the app
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 508 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
