Orbi WiFi 7 RBE973
Reply
RBK53 chatty satellite
EliiottB
Follower
All:
I have a chatty satellite who is constantly trying to initiate ftp from several sites, apprently looking to dl something undesirable, and it appears I am going to need to do a clean install of the firmware in hopes of getting rid of it
Question is, how?
Anyone?
PS: attempted prot 6, port 21 to: 52.208.82.166, 34.243.216.129, & 34.241.19.122 approx 300 times in 12 hrs
How do I shake this?
eliott.bay-AT-gma1l.com
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
CrimpOn
Guru
Re: RBK53 chatty satellite
It is rather unlikely that an Orbi satellite is attempting to download files from anywhere but Netgear's firmware site.
However, it is easy to reset the satellite to factory.
Stick the end of a paperclip into the tiny Reset hole next to the power cord until the Power LED turns amber and begins to blink.
This will reset the satellite and you can then sync it to the router again.
Message 2 of 3
Guru
To test this, I would turn OFF the RBSs for a while. See if logs still report something.
@EliiottB wrote:
All:
Question is, how?
Anyone?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 488 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
