Reply
RBK53 networkwing with Cox Arris tg1682g
esko1954
Cox just replaced their cable modem with Arris tg1682g.  I would like to have one seamless network.  Currently, if i connect a device to the router than it can't speak to any devices on the Orbi.  Is it possible to bridge the two togehter for seamless wired and wireless environment.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: RBK53 networkwing with Cox Arris tg1682g
Hello esko1954
You would have to look in the settings of your modem to find a modem only option this should allow you to use orbi as your main router.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1487 views
  • 0 kudos
  • 2 in conversation
Announcements
